It is currently Sat May 25, 2013 8:50 am
View unanswered posts | View active topics
Italeri Sd. Kfz 232 6 RAD
Vinnie Branigan
Joined: Sat Feb 28, 2009 10:33 am Posts: 16022 Location: Runcorn, Cheshire
 Re: Italeri Sd. Kfz 232 6 RAD
Going by what you say about the carrier film not being that visible in person, I suspect they haven't actually silvered, but that the carrier film is showing up on the pics because of the differential between the surface finishes, in which case as you say it might dissapear when you apply a flat coat...which would be my net step. Failing that, drop Paul from Little Cars a line, he carries a line including the strongest decal setting solution you can get...ask him about it, and then use with caution!  Vinnie
| Wed Oct 26, 2011 8:06 am |
Simon Briggs
Joined: Sat Sep 18, 2010 10:24 am Posts: 947 Location: Hampshire
Cheers Vinnie I'll give that ago next time round. I say that because even after two coats of Klear the first wash of oils destroyed the decals completely.
Peddinghaus do warn of this on their instructions but I thought a couple of coats would be sufficient to protect it, I'll have to try an acrylic gloss varnish on when I reapply, other than that I'll have to settle for bright clean decals applied once everything else is finished!
I used Microsol/Microset on this application so it should have worked. Oh well back to the bench and I'll update when I have something to show other than disaster.
Simon
_________________ It's only a hobby
| Wed Oct 26, 2011 8:57 am |
Vinnie Branigan
The stuff Paul has is much, much stronger than the Micro products. I must admit I've never, ever had decals destroyed by a wash? That's one manufacturer's decals I'll steer clear of in future.  Vinnie
| Wed Oct 26, 2011 9:19 am |
Chris Smith
Joined: Fri Feb 27, 2009 1:01 pm Posts: 6292 Location: Left behind after the Cold War
A friend of mine has had trouble with Peddinghaus decals dissolving too which given the price he was more than a little miffed about.
_________________ SAS: Who dares wins Paras: We always win Marines: We dare to win REME: Who cares who wins, we're laughing all the way to the bank
| Wed Oct 26, 2011 10:03 am |
Simon Briggs
It's a real shame about Peddinghaus because they have a varied collection of interesting sets. I'm going to try again, just waiting for Paul (Little Cars) to get back to me re the decal solution. Then I'll try various varnishes to seal the decals before applying more washes.
Simon
| Wed Oct 26, 2011 4:01 pm |
Simon Briggs
While I wait for the "aggressive" decal stuff from Paul I can't really do much more with the 6 RAD so I thought I'd show you some of the figure progress I've made. This is the SD man in his black uniform, still got some work to do, shirt, belt kit and badges. Also I have his MP 41 to complete. He looks somewhat shiny as I ended painting the black uniform in oils.  The SS officer I did earlier in the year, not too sure about the camouflage pattern, it still needs a bit of fading which I'll do with white oil paints and see how it goes from there.   And finally my dead partisan, just the face done in oils, I kept the hue very pale and added some pale blue to the mix to give that dead bloodless pallor, hope it carries through in the photo's.  I'll try and get some more done this weekend. Simon
| Fri Oct 28, 2011 4:14 pm |
Simon Briggs
I've had a bit of a hiatus on this project, firstly problems with Peddinghaus decals and secondly I've well and truly buggered up my left knee, which makes sitting at the bench a little painful, to say the least. On Vinnie's advice I spoke to Paul from Small Cars and got some Daco Red decal solution, this was better than Micro Sol/Set but still didn't dissolve the carrier film, so I trimmed the decals as close as I dare to the art work.   I have also done some chipping and scratches and a little weathering, still more is needed if the upper decks are to match what I've done underneath.   I have also made some progress on the figures, the SS officer and SD Poleizi man are now done. The weapon in the SD's hand is (supposed to be) a MP41, this was the MP40 working parts attached to the butt and stock of the MP28. I actually used the butt and stock from a KAR 98, if I had the MP28 I would have used that instead.     The next two are still WIP and need quite a lot of work, especially to calm down the camouflage.   The final figures are still in undercoat. All comments welcome. Cheers Simon
| Mon Nov 07, 2011 10:33 pm |
Yngve
Joined: Fri Feb 27, 2009 1:02 pm Posts: 3566 Location: 4th Fjord to the left
Great work Simon. Some toning down of the camo on the kneeling figure and it`ll be perfect.And the vehicle looks really kool with the polizei decal
| Tue Nov 08, 2011 12:08 am |
Justin Wooding
Joined: Tue Apr 07, 2009 12:23 pm Posts: 2723 Location: Seymour, Victoria, Australia
Hello Simon, Looking good! I really do like the kitbashed MP41, looks fantastic Woody...
_________________ If something doesn't look right.......then it probably isn't!
| Tue Nov 08, 2011 3:02 am |
Dario Risso
Joined: Wed Jul 01, 2009 4:58 am Posts: 919 Location: Rosario, Argentina
Nice update, Simon. I hope you feel better Darío
| Tue Nov 08, 2011 4:02 am |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
