It is currently Tue May 21, 2013 7:27 pm
View unanswered posts | View active topics
Mg nest-Kinderheim Height 1/35
Yngve
Joined: Fri Feb 27, 2009 1:02 pm Posts: 3566 Location: 4th Fjord to the left
| Fri Oct 28, 2011 3:01 pm |
Simon Briggs
Joined: Sat Sep 18, 2010 10:24 am Posts: 947 Location: Hampshire
 Re: Mg nest-Kinderheim Height 1/35
Very poignant looking scene Yngve, will look stunning with you doing it, looking forward to this immensely.
Simon
_________________ It's only a hobby
| Fri Oct 28, 2011 4:04 pm |
Pam
Now I see why you were looking for that MG stand. I assume one comes in the figure kit so you are good to go? Pam
| Sat Oct 29, 2011 1:17 am |
Deano Raines
Im in Yngve, always a pleasure to watch your scenes unfold.
Deano
_________________ ' A Panzer isnt just for Christmas '
| Sat Oct 29, 2011 1:26 am |
Yngve
Thanks for the interest fellow geeks  I have almost all the parts I need to really start this one. Im still on the lookout for a frame/base to put it on,I had a pefect one,but I used it on the Finland Forest vignette I made a few onths ago,but Im off to the second hand shop before it closes today.Aaand I need to find a wire that I can cut in lenghts to produce thousands of spent shells,and then I`ll use just a few of the Adler Nest ammo in strategic places for the macro lense to capture for the final pictures. Having a closer look at the person in the photo,it looks like he has a patch over his left eye,which should easily be sorted with some putty,unless there is a perfect Hornet head with an eye-patch...
| Sat Oct 29, 2011 11:27 am |
Matt Parvis
Joined: Sat May 16, 2009 7:11 pm Posts: 3150 Location: Due north of Washington DC in Maryland
Yngve, I would think you could find some brass wire that would do the trick. Over here I see it most often in with the stuff used for hanging pictures in craft or hardware/DIY stores.
_________________ We won't bring the muskets, we won't cause the pain, But we're good for some headaches, and tough to clean stains.
| Sat Oct 29, 2011 12:21 pm |
Shawn Ramsey
Joined: Wed Jul 07, 2010 4:53 pm Posts: 1320 Location: South Carolina
Count me in Yngve. It is amazing all the uses the half track crews sets has.
Shawn
| Sat Oct 29, 2011 3:55 pm |
Gary Boxall
Joined: Fri Feb 27, 2009 9:14 pm Posts: 6231 Location: Auckland, New Zealand
As Matt suggest, brass wire would be perfect. And at that diameter, easily cut with a sharp modelling blade. The other bonus is that no painting is required either. I'd just heat the wire first (makes it softer and easier to cut) but will also burnish it - just like a real spent cartridge case. Gary
_________________ Never hold discussions with the monkey when the organ grinder is in the room. Sir Winston Churchill
| Sat Oct 29, 2011 9:16 pm |
Gary Boxall
As a thought, why not make the core of the spent cartidge mound from something like clay and then place the brass rod/shells on top. You could then send it over to Steve R who could cast it in resin for you Gary
| Sat Oct 29, 2011 9:18 pm |
Stewart McNair
will look forward to this, especially the figure painting  loads of info on that please
| Mon Oct 31, 2011 12:57 am |
Who is online |
Users browsing this forum: Gary Boxall and 0 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
