It is currently Fri May 24, 2013 4:37 pm
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Sd.Kfz.10/5 - "Its Mine Now"
Post Re: Sd.Kfz.10/5 - "Its Mine Now"
Thank you Steve and Vinnie!! Gad to have you along for the ride! ;)
Tue May 01, 2012 10:00 pm
Not much to report other than I am off my game in plastic land. The mojo is hurting a bit due to too many things going on recently. Holding it together just the same, went out and swung the golf club a bit to clear the cobwebs! Enough of that Poo and here is some pics...
I ran some horizontal planking first (not seen) and started to make some roof panels. Picked up some extra thick Aluminum foil from work and doctored up some Lap-seam panels.
This is just after giving the panels the treatment. A little etching solution to weather them up a bit before installation. As you can see in the last picture above, the panels appear to be just blackened. After drying some natural rusting pigment show up.
PLEASE NOTE: I am using a PCB Etching solution. These chemicals are dangerous and can be harmful if used incorrectly. I have taken the time to learn all the dos and don'ts when using this product and have read the MSDS (SDS) (Material Safety Data Sheet) and I use all necessary PPE (Personal Protection Equipment), like safety glasses, gloves and plenty of ventilation. This is a similar solution used by the Photo Etching Companies to make PE Add-on sheets. Some really great stuff and even fun to use...when used with caution and safety!
Back to the build!
Thinking they will pass. After I took the pics today, I added a quick filter to some spots and the entire roof. I need to finish the top rows of siding and I may pop on a fascia board as well. Got a ways to go on this but it is moving forward.
Thanks for keeping me company!! ;)
Wed May 02, 2012 11:45 pm
All looks very nice, Todd! I love the Demag and I love when the wood looks like...wood!
Good point with the safety advices, thanks for that
Darío
Thu May 03, 2012 2:34 am
Todd - that is an astonishing finish, and as Dario says - the wood just looks like (very distressed) wood :!:
Wow :shock:
Thu May 03, 2012 7:42 am
Hi Todd
Your building just gets more and more impressive :D Its level of dilapidation just doesn't do justice to the quality of how well you have built it, but like you said its the "day job" influence :D
Cracking stuff
Thu May 03, 2012 8:30 am
Very impressive work Todd - looking forward to more :)
Paul
Thu May 03, 2012 4:19 pm
Gentlemen, Thank you very much!
Hopefully the main structure will be finished soon. I was working with the tracks a little last night and plotting the ground work that needs to be done!!
Thu May 03, 2012 5:13 pm
Hi Todd, great attention to detail you are showing -- the old building is really looking the part!
Cheers,
Ian
Nostalgia ain’t what it used to be
Newbury Scale Model Club: http://www.newburyscalemodelclub.org.uk
Thu May 03, 2012 8:13 pm
Thanks Ian, I appreciate the kindness!! ;)
Fri May 04, 2012 2:11 am
A little update. I have been working on the base a little in between games and last night added some dusting which is getting chipped back some tonight and more weathing layered on. I hope to have more soon.
Thanks for stopping in!!!
Wed May 09, 2012 11:47 am
Users browsing this forum: Deano Raines and 1 guest
