It is currently Fri May 24, 2013 4:29 am
Post new topic Reply to topic  [ 5 posts ]
 Removing plastic coating from aluminum containers
Post Removing plastic coating from aluminum containers
Hi All
Greetings from New Zealand (Rightful Home of the Rugby World Cup).
This should be my first post here.
I've been following Vinnies builds and they are sweet by the way however I have a question.
The aluminum t/away containers we have here (and I suspect you have) have a thin plastic coating do you
A) remove the coating
B) leave in place
If A how do you remove that coat coating I've tried to scrap then lift it with no real success.
Please help.
chris :geek:
Fri Mar 23, 2012 12:34 am
Post Re: Removing plastic coating from aluminum containers
Hi Chris
Welcome to the site.
The Tray's I use are just the Foil No plastic coating.
I use takeaway or Trays from Frozen supermaket items. Just give a very good clean,
never had any problem.
Fri Mar 23, 2012 10:58 am
Chris, try the hardware department of your local supermarket. You should be able to find sets of foil pie dishes etc., that don't have plastic coatings. Very cheap too. :)
Fri Mar 23, 2012 12:20 pm
Hi Chris
Foodtown have plenty of cheap foil dishes/trays as suggested above.
Fri Mar 23, 2012 6:46 pm
Cheers Guys
Thanks for the input....I'm off to the Supermarket.
Regards
Sat Mar 24, 2012 4:59 am
Users browsing this forum: No registered users and 0 guests
