Chris Smith
Joined: Fri Feb 27, 2009 1:01 pm Posts: 6292 Location: Left behind after the Cold War
 Need airbrush advice
I've been having some problems with the Neo airbrush. The main one is that the air valve keeps sticking on and full on at that. Anyone have an idea what might be wrong and how I can fix it?
_________________ SAS: Who dares wins Paras: We always win Marines: We dare to win REME: Who cares who wins, we're laughing all the way to the bank
| Tue Nov 22, 2011 4:57 pm |
vlad
 Re: Need airbrush advice
could it be a dry gasket that is binding the valve? maybe a little lubricant.
| Tue Nov 22, 2011 4:59 pm |
Rob Matthews
Chris - I've checked the Iwata site - here's the pdf parts breakdown http://www.iwata-medea.com/images/iwata-pdf/NEO%20IM-Long_REV2.pdfPage 7 - Part 14 - is the Valve body O ring Its this (same as my HP-C) This is likely to be the culprit Either remove it - try a cocktail stick and if that breaks winkle it out with some metal implement - it sits snug in a metal bed. Wash it with water - With respect to Vlad - when I've used the Iwata lube on this bit - its dried to a cake a bit like the paint/cleaner, the problem that's caused this. It's worth cleaning the plunger - (part 5 for you) similarly. Alternatively you can leave the O ring in place and use one of the fancy groovy cotton buds that come smaller and pointed unlike the normal. You'll know when you see them. Just dip in de-ionised water stick in the O ring and wipe around. That should do it - it will need doing every couple of sessions - I wash my AB through with water now rather than cleaner at session-end to prevent this HTH Rob
| Tue Nov 22, 2011 7:30 pm |
Stewart McNair
had a similar thing with my Harder and Steenbeck, used a drop of olive oil. worked like a dream.
| Tue Nov 22, 2011 7:55 pm |
Vinnie Branigan
Joined: Sat Feb 28, 2009 10:33 am Posts: 16020 Location: Runcorn, Cheshire
I've not experienced that with mine Chris, so I can't help with a solution, other than like Rob, I always run clean water through after using anything to clean it, before putting it away?
| Wed Nov 23, 2011 10:03 am |
Chris Smith
Thanks for the advice guys. To remove the pistion the whole air valve needs to come off and then there's a tiny O ring. As a first attempt I cleaned it by wiping the inside with a cocktail stick, reassembled and tried it. It was better but after a while started sticking again so I then stripped it and tried Stewarts suggestion of the olive oil and job's a good 'un  I also found the nozzle cap was blocking and the only way I found to really clean that was a cocktail stick with some airbrush cleaner on it. Chris
| Wed Nov 23, 2011 12:09 pm |
Pam
I have aslo cleaned part #3 Nozzle from the large end with a few hairs picked up from a flat paint brush dipped in your favorite cleaner. Do this in and out a few times to clean it out. You can take part #18 Air Valve Guide out with a pair of small tipped tweasers poked in the 2 slots and turn as it's threaded then clean the whole thing from that end. Little harder to get back together though as the spring is there pushing while you are trying to screw it back in. Pam
| Thu Nov 24, 2011 2:32 pm |
Shawn Ramsey
Joined: Wed Jul 07, 2010 4:53 pm Posts: 1336 Location: South Carolina
Your not the only one with this problem. Mine does the same thing. I will have to try the olive oil. Besides this little problem I love this airbrush. Sprays very nice.
One of the guys in my model club used to be a professional airbrush painter. He got this Neo and has nothing but good things to say about it. Say he had bought $400 plus airbrushes and they can't get the results he gets with this. Most of the airbrushing he does now is with the Neo.
Shawn
| Sun Jan 08, 2012 5:54 pm |
Stewart McNair
as a side note I found the problem was caused by over cleaning with agressive Badger airbrush cleaner when doing a deep clean on the brush. This is great for getting all the dirt out of the brush from deep areas in the airbrush but not good on your rubber/plastic washers which need re-moisturing after to restore their flexibility. Do not know if that is the cause for your problems but worth bearing in mind
| Sun Jan 08, 2012 6:32 pm |
Paul Fitzmaurice
Just found this thread.
O rings swelling is usually caused by aggressive cleaners getting into places they shouldn't be. If you remove it and leave it somewhere warm for a few hours to de-gass they are usually OK.
On H&S the two problem areas were the top o ring on the air valve and the one on the front air cap. Manly because the market they were designed for was water based paints. H&S have now upgraded these, the air valve one is now teflon and the air cap is vitron rubber.
They also have a higher grade PTFE O ring available for the paint cup seal, and the internal needle seal can be upgraded to a triple needle seal if required.
Swelling is not normally so much of a problem on Iwata brushes, but the Neo is entry level price, so I guess the standards are going to be lower.
I would recommend using Iwata super lube on these parts and on the needle every now and again to keep them clean. It's £6 a tube and will last years.
| Thu Jan 12, 2012 1:10 pm |
