It is currently Tue May 21, 2013 5:02 pm
Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
 AVRE
Post Re: AVRE
Now you tell me :lol:
Okay, so following its abortive attempt to imitate a Ju87, the rear deck is all fixed up. The original blue 'rag' was made from milliput and broke up with the impact so I replaced it with an air recognition flag using foil.....
The rear panel received PE telephone and first aid boxes.
The 'T' often seen on these boxes was painted using a stencil, but the first aid box proved more challenging. My collection of spare decals failed to come up with what I needed so I needed to do things the hard way :roll: The only letters I had which were of a suitable size were from an Archer dry transfer set. I had to cut out the individual letters to make up the words required....
I think I pulled it off :?
Wed Apr 04, 2012 3:33 am
Post Re: AVRE
The rear section of cable is made from ship modelling 'rope'. I simply run a flame along the string to remove the 'fluffy bits' and then made a loop each end to represent a steel hawser. I then simply painted it steel. The release mechanism has it's green basecoat on at this stage and will be further weathered when the front cables are in place....
Wed Apr 04, 2012 3:52 am
Post Re: AVRE
Front cables attached....
Cables and mecahnism still need to be weathered. Once they are done I'll add a light coat of dust around the running gear etc.
Also made a start on the figures I'll be using with this. Alpine's sublime British tank crew in their pixie suits....
Wed Apr 04, 2012 5:07 am
Post Re: AVRE
Gary,
awesome as always!
Even in close-ups everything still looks perfect.
I actually like the "new" look of the release mechanism....
I should look into my references, but wasn't the mechanism released manually with a cable that ran into a hatch????
Frerik
Wed Apr 04, 2012 7:25 am
Post Re: AVRE
Thanks Frerik :D
The 'cable' has since been made using lead wire but I hand't fitted it in those pics. I thought I read somewhere that there was a small charge in the mechanism which could be detonated to release the mechanism if under fire via detonation cord. Otherwise it was released manually. Happy to hear what your references say though.
Cheers
Wed Apr 04, 2012 7:37 am
Post Re: AVRE
Bucket has been painted and weathered to represent an enamel coated bucket typical of that era....
Release mechanism weathered. The release cable has been attached to the mechanism and still needs to be fixed to appear it is going through the loaders hatch....
So far....
Wed Apr 04, 2012 9:23 pm
Post Re: AVRE
Gary, that looks great, amazing work. Certainly a show stopper if you ask me.
We won't bring the muskets, we won't cause the pain,
But we're good for some headaches, and tough to clean stains.
Wed Apr 04, 2012 9:39 pm
Post Re: AVRE
Gary-
this is my all time favorite model you've done since the last one- and until the next one....
:D
Mk IV AVRE is a model that should have been kitted 20 years ago!
Great looking model Man!
Steve
www.celticwerks.net
Wed Apr 04, 2012 11:40 pm
Post Re: AVRE
Thanks guys :mrgreen:
Steve - plan to start working on one of your bases to put this on over the weekend ;)
Thu Apr 05, 2012 1:19 am
Post Re: AVRE
Aerials next.
First up is the excellent LionMarc set somplete with protective guard....
Everything solders together nicely for strength....
The other aerial is from Passion mdels. You may be able to make out the wing nut clamp I've added to the base as this always seems to be missing on kits :?
I've also added further weathing using diluted acrylics, oils and pigments....
Thu Apr 05, 2012 11:32 pm
